S-10 & Blazer 1982-2005
help 1994 chevy blazer
Old Nov 6, 2006 | 9:38 PM
katievp's Avatar
Default help 1994 chevy blazer
i have a 1994 chevy blazer that is just killing me, it didnt want to start you had to keep cranking it to get it to finally start.so i replaced the starter ,the coil,the pick up coil, the ignition module it worked for awhile then same problem again,well replaced fuel filter new plugs wire, rotor and cap same problem still, then replaced spider assembly because it was leaking, replaced every sensor because it blew a code for the erg vale, so replaced every sensor on engine, now you have to hold gas pedal down and crank it to get it running it also blows carbon out exhaust now when first started. please help at my wits end thank you
Old Nov 7, 2006 | 12:23 AM
70mopar's Avatar
Default RE: help 1994 chevy blazer
give us a little more info katievp, what's the engine? the mileage?
Old Nov 7, 2006 | 8:05 AM
katievp's Avatar
its a 6 cylinder vortec with 97,000 miles on it
Old Nov 7, 2006 | 10:39 PM
NCHEVYHEVN's Avatar
CPI?
It honestly sounds like you have no idea what you are doing. You could have took all that money you just threw at it and took it to a dealership and probably got it fixed.
Are you sure you installed that spider correctly?
Old Nov 8, 2006 | 8:12 AM
katievp's Avatar
it is a cpi, yes the spider is correct, and it didnt cost a penny when you know the right people.
Old Nov 10, 2006 | 8:11 AM
katievp's Avatar
took it to chevy dealer there was leak in the gas line.
Old Nov 10, 2006 | 10:30 PM
70mopar's Avatar
don't u just [sm=smiley27.gif] the simplist thing to diagnose and fix.[sm=noooo.gif]
Old Nov 24, 2006 | 5:27 PM
katievp's Avatar
yeah, shes running great now
dj1831
Oct 19, 2014 10:02 PM
Blazinjake
K5 Blazer
Apr 10, 2013 9:14 PM
zachsny
Nov 15, 2011 7:19 PM
s10blazerproject
Nov 28, 2010 12:01 PM
habamock
Mar 12, 2008 4:55 PM
