S-10 & Blazer 1982-2005
Help Replacing Door Hinge Mount
Old Oct 23, 2014 | 1:43 PM
BigBadOsker's Avatar
Default Help Replacing Door Hinge Mount
Hi, Im somewhat mechanically inclined but I need some help removing this door hinge and replacing it. This is a picture of the passenger side, the driver's side is what needs replaced but I do not want to open the door because the pin has been ripped from the hinge and it's a pain to shut the damn door.
Does this need to be heated up with a torch and then removed or something? It's attached by some kind off alloy or something. I'd really like to get this done; It's a pain in the butt getting in and out of the vehicle. Any help is greatly appreciated.
Old Oct 24, 2014 | 7:24 AM
its welded to the a-pillar. your not getting that off neatly without a plasma cutter. It not made to be removed.
They do have hinge pins and bushings replacement parts. Will they not work for you?
Old Oct 24, 2014 | 9:03 AM
The whole hinge needs replaced because I think the door was bent so far back that it separated the metal where the pin locks. I guess I'll have to take it to a shop, but first. I have to find a replacement hinge. That's probably not going to be easy. Any suggestions online? I appreciate the reply.
Old Oct 25, 2014 | 7:17 PM
Gramps43's Avatar
The hinges are spot welded to the pillar and the door, you need to drill out the spot welds to get the hinge off. The replacement hinge bolts on, here's an example of the hinge on e-bay.
Dorman 924-107 Hinge Assembly (Fits: 1996 S10)
  • $47.14 List price: $114.49
  • Buy It Now
  • Free shipping
Old Oct 25, 2014 | 11:04 PM
so the bead around the hinge is sealer then and not a weld?
Old Oct 26, 2014 | 12:37 PM
Gramps43's Avatar
El correcto good sir, keeps the moisture out so corrosion won't take the door off when you least expect. Use a good silicone caulk when put the new hinge to keep it rust free.
Old Oct 26, 2014 | 9:50 PM
@Gramps43
Thanks for the reply. I am going to attempt to get this off tomorrow, however, I can't find a replacement part on ebay. The link you provided to ebay is not the correct hinge. I am going to have to try a junk yard around here. Does anyone have any suggestions where I can find this part?
Old Oct 27, 2014 | 5:37 PM
Gramps43's Avatar
Me thinks you would be better off getting a new one. Anything you would find ate the JY would have to be removed in the same way you have to remove the bad one and you wouldn't get the backing plate and cap screws to in stall it. There are lots of hinges listed on e-bay you should be able to find the one you need. If not then lmctruck.com has then, a bit more spendy but they will fit.
jfonod
Sep 19, 2024 11:54 AM
Redevilrxp
46
Oct 31, 2019 5:27 AM
2007BURB
Jun 13, 2009 12:52 AM
eagle98
Apr 21, 2008 9:09 PM
jcw1500wt
Mar 24, 2008 11:07 PM
