S-10 & Blazer 1982-2005
High Performance Water Pumps
Old Aug 1, 2009 | 4:50 PM
Larry the Blazer guy's Avatar
Default High Performance Water Pumps
I need to learn about options for water pump replacement for a 1995 Blazer. Are there electric options/ hiflow replacements?Thanks.
Old Aug 1, 2009 | 5:39 PM
EvansBlue's Avatar
Don't think theres any electric pumps. I wouldn't get one anyway. If you want more flow, you need to change the thermostat. You wouldn't really gain anything from putting more coolant through anyway, you'd just have a huge temperature swing.
Old Aug 2, 2009 | 3:32 PM
Thanks for the feedback. I am going to put the Taurus 3.8 electric fan on the Blazer. I have problems overheating while waiting in traffic (1.5 hours to cross from Mex back to US). My brother-in-law has installed the fan on his Jeep with great sucess. Do you have any other recommendations. I will check into the termostat and flush/clean the radiator. What anit-freeze coolant do you recommend? Thanks.
Larry
Old Aug 2, 2009 | 4:33 PM
suzuki-guy's Avatar
I would use Dexcool It's what Gm uses.
Old Aug 2, 2009 | 8:53 PM
EvansBlue's Avatar
The Taurus fans are the closest fit, but its really only a cheap junkyard alternative to buying a fan kit specifically made to replace the fan shroud on the Blazer. I would buy the kit.
Old Aug 4, 2009 | 7:34 PM
Thank you for the great feedback. You guys give me a lot to think about. L
Old Aug 5, 2009 | 5:28 AM
drperry's Avatar
People use the taurus fan, because most of the purpose built ones are obnoxiously expensive for how well they work, lol.
Still, no electric fan that I know of, that fits, will pull anywhere near as much as the mechanical fan...
Old Aug 6, 2009 | 11:20 AM
Question electric fan
I want the electric fan because at idle the mech fan does not deliver in the heat of AZ and Mexico. I set in line to cross the border for about 1.5 hours. Any input on water pumps? Thanks for the feedback.
L
dragracemaniac
May 16, 2012 8:17 AM
Eric L
Sep 27, 2009 6:36 PM
djkk54
May 27, 2009 5:19 AM
justin amdahl
Nov 26, 2008 9:40 PM
northcarolina27959
11
Dec 4, 2006 2:35 PM
