S-10 & Blazer 1982-2005
High Rpms
Old Oct 18, 2012 | 4:28 PM
BillFos780's Avatar
Default High Rpms
I have a 2003 s10 4.3 auto when I am driving at 60 rpms are abought 2500 and when I put the hammerdown to pass it is a 6000 rpm like that I have no idea what is going on it. Is it the motor or trans want to know what is wrong I bout it new in 2003. thanks all
Old Oct 19, 2012 | 2:58 PM
Jwhitworth's Avatar
If I understand you correctly it sounds like your transmission is slipping...that's usually the culprit whenever your speed does not increase exponentially compared to your rpms (or clutch in a vehicle equipped with a manual transmission).
Old Oct 20, 2012 | 3:09 PM
BillFos780's Avatar
Is this a costly Fix she has a 140,000 miles on it how long I Have on this trans and is it worth the fix
Old Oct 29, 2012 | 7:14 PM
Steven Shepard's Avatar
if its a auto you have to get the trans rebuilt or replaced so 2-5000.
if its a manual a clutch will probably be around 400 installed
Old Nov 1, 2012 | 8:27 AM
BillFos780's Avatar
Its a Auto abought how long do I have left on it and if the trans gose will the motor blow as well. Is there any thing I can put in the trans to make it last longer or is it shot to hell.
Kohen Marzolf
Feb 12, 2013 2:07 PM
DavidS
Apr 9, 2010 8:08 AM
GermanyD2009
Jan 24, 2009 10:19 AM
benduran9
Jul 27, 2008 8:37 AM
pettitk
Aug 4, 2007 9:03 PM
