left side signal light malfunction
I have a 2000 S10 PICKUP 3 doors and the left blinker statred to work real fast thought i was a burnt bulb put new bulbs in front and rear samething happening. Right side works fine took bulbs and switch them around and still left side blinks fast. Put in a new flasher still left side blinking fast any help would be appreciated
![](https://chevroletforum.com/micons/m8.gif)
Howdy, alexseto. Have you replaced all the bulbs with new ones? and checked the ground wires to the chassie. There are black ground wires in the rear that are attached with 10mm bolts they could be loose.
Also check your fueses.
[sm=type.gif]
[sm=type.gif]
You might also want to check the trailer harness if there is one, mine had the same problem because there was a short in the trailer harness. It didnt make much sense the way it happened, but it worled when i fixed the shorted wires so whatever.
Yogi
December 12th, 2021 6:25 PM
ericconn
June 19th, 2012 9:56 AM
RomanGuzi
October 2nd, 2011 11:40 AM
Michael C
October 9th, 2007 12:11 AM
