S-10 & Blazer 1982-2005
left side signal light malfunction
Old Oct 25, 2007 | 12:55 PM
alexseto's Avatar
Default left side signal light malfunction
I have a 2000 S10 PICKUP 3 doors and the left blinker statred to work real fast thought i was a burnt bulb put new bulbs in front and rear samething happening. Right side works fine took bulbs and switch them around and still left side blinks fast. Put in a new flasher still left side blinking fast any help would be appreciated
Old Oct 25, 2007 | 1:22 PM
sickvortech1's Avatar
Default RE: left side signal light malfunction
Howdy, alexseto. Have you replaced all the bulbs with new ones? and checked the ground wires to the chassie. There are black ground wires in the rear that are attached with 10mm bolts they could be loose.
Also check your fueses.
[sm=type.gif]
Old Oct 26, 2007 | 5:05 PM
golfer's Avatar
I had the same issue on my 03 ... the multifunction switch stalk needs to be replaced.
Old Nov 4, 2007 | 9:45 PM
sullivkj's Avatar
You might also want to check the trailer harness if there is one, mine had the same problem because there was a short in the trailer harness. It didnt make much sense the way it happened, but it worled when i fixed the shorted wires so whatever.
Yogi
Dec 12, 2021 6:25 PM
270BBR
Feb 15, 2014 8:03 PM
ericconn
Jun 19, 2012 9:56 AM
RomanGuzi
Oct 2, 2011 11:40 AM
Michael C
Oct 9, 2007 12:11 AM
