S-10 & Blazer 1982-2005
Motor Mount Removal ...HELP...
Old Sep 18, 2009 | 6:45 PM
Siliconasp's Avatar
Default Motor Mount Removal ...HELP...
Need some help and suggestion for removal of the engine mount on a 2002 Blazer 4x4. Passanger Mount has only the lower of the 3 screws remaining. Have already removed the 2 upper bolts and having issue remove lower bolt.
How do I remove this damn bolt. There are 2 metal tabs that are part of the lower mount plate in the way, also the break hard lines make it hard to get access with a standard and offset wrench, hell even a 15mm socket on a universial joint will not fit... Help
As for the driver side, having one hell of time finding path to the bolts around the transfer case is way.
HELP. Chilton Manual is about useless, and having issue finding resources on the web. Anyone help...
NEVER MINE, I FIGURED IT OUT>>>> Time to go Engineer Hunting in Detroit for the guy that designed the engine bay layout for this truck...
Jake van Meter
Mar 13, 2012 12:59 PM
sparcotsi
Apr 23, 2009 10:34 PM
fisch79
Feb 10, 2008 8:34 PM
badluck
Nov 1, 2007 10:00 PM
