S-10 & Blazer 1982-2005
No Spark!! 89 blazer s10 tahoe
Old Jun 4, 2009 | 5:13 PM
  #11
Hollerdog's Avatar
Sorry i did say distributor but it was only the cap. So if there is no voltage to the leads what would be the problem?
Old Jun 4, 2009 | 5:14 PM
  #12
Mike Sigmond's Avatar
ROTM Coordinator
Originally Posted by suzuki-guy
You said you replaced distributor right? Or just the cap? If you replaced distributor did you time it?
He would still get spark even if he did that
Old Jun 4, 2009 | 5:17 PM
  #13
suzuki-guy's Avatar
Correct but it would be real weak maybe even impossible to see in the daylight! But i would lean toward testing your coil! And what kind of plugs wire and cap did you get?
Old Jun 4, 2009 | 5:24 PM
  #14
ROTM Coordinator
I edited post #9 in this thread in case you missed it, its a GIF that shows how the coil wiring works
Old Jun 4, 2009 | 5:27 PM
  #15
suzuki-guy's Avatar
You sure wink a lot Mike! LOL
Old Jun 4, 2009 | 5:28 PM
  #16
Hollerdog's Avatar
Going out to check that right now, I'll get back to you all in a bit. Thanks
Old Jun 4, 2009 | 5:30 PM
  #17
ROTM Coordinator
If I wasnt married to a WOMAN, it might be scary
Old Jun 4, 2009 | 5:31 PM
  #18
Hollerdog's Avatar
Got the parts from advanced auto Exact wires, BWD cap and rotor, ac delco plugs
Old Jun 4, 2009 | 5:55 PM
  #19
suzuki-guy's Avatar
Your sure you got the plug wires on in the correct firing order right??
Old Jun 4, 2009 | 5:58 PM
  #20
ROTM Coordinator
Originally Posted by Hollerdog
Double checked the firing order and its right, even if it was wrong i should still get spark. Ran fine before so timing should be ok to.
Jk man, now I am just f-ing with ya.
