S-10 & Blazer 1982-2005
Oil pressure gauge acting erratically
Old Jan 5, 2014 | 5:20 PM
blackblazer03's Avatar
Default Oil pressure gauge acting erratically
Hi,
Recently the oil pressure gauge on my 2003 Blazer has been going in and out randomly. Each time the gauge goes to 0 the "check gauges" light comes on.
I'm not really a car guy but it seems to me like a sensor is on its death bed. Do you guys know any other causes of this behavior?
thanks!
Old Jan 5, 2014 | 5:26 PM
Edit: If it helps, i have not noticed any kind of decreased performance, gas mileage, or anything like that while driving my blazer. Just the gauge going in and out without any patterns.
Old Jan 18, 2014 | 5:29 AM
MrJason's Avatar
Try checking if you have engine oil. You might actually be low on oil.
Shoots
Old Jan 18, 2014 | 10:58 AM
marck83's Avatar
Check your oil level like mr Jason said and look at replacing your oil pressure switch
Old Jan 18, 2014 | 11:11 AM
From 2003 to 2006 GM was having problems with the stepper motor that operates the gauges. There was a recall on these. Check with the dealer if your truck was one of the recalls. They may still be able to repair it for free. Usually all 6 of the gauges will fail. If this is your problem, it is about $600.00 for the dealer to fix it if it is not on the recall list. You can also fix it your self if you can solder for about $25.00 by buying the stepper motors and replacing them yourself.
Steelman512
Jun 8, 2023 2:51 PM
not_a_car_dude
Sep 15, 2013 7:41 PM
graysilm
Mar 25, 2008 12:30 PM
ChevyBabe
May 23, 2006 5:48 PM
