S-10 & Blazer 1982-2005
Please help diagnose this noise
Old Jun 13, 2014 | 3:20 PM
cruisinfanatic's Avatar
Default Please help diagnose this noise
My 98 s-10 2WD 4 cyl with 135K miles has been making this grinding noise in the rear. Sounds exactly like grinding from really worn out brakes.
video 1 with drums on
video 2 with drums off
I can't tell where it's coming from. Both sides equal so I'm suspecting differential.
Shop looked at it and came up with bad U-joint and recommended differential service.
I fixed the u-joint. Fluid level ok in differential
Old Jun 24, 2014 | 7:56 PM
skruzich's Avatar
sounds like the pinion gear in the differential has broken a tooth. Get ready fo replace rear end. When was the last time you checked teh oil in the differential
Old Jun 25, 2014 | 5:50 AM
one of the first things I checked. Level was fine
Old Jun 26, 2014 | 12:42 PM
skruzich's Avatar
Did you open up the pan and look at the gears? I'm betting there is a broken tooth or two or at least they are chipped off somewhere
Old Jun 26, 2014 | 12:43 PM
skruzich's Avatar
One other thing it could be is bearings. Might be the axel bearing but you'll have to pull it out to check it. and while your doing that check the ring gears and pinion in the differential
Old Aug 15, 2014 | 7:16 AM
I'm back and still baffled. I took off the cover of the differential to get a see inside. Didn't see any obvious wear or damage.
Also have what seems to be breaks dragging. Gets worse after driving for a few minutes. Will actually hold the truck on slight incline. Could this be related?
Old Aug 17, 2014 | 9:40 AM
southerencustoms's Avatar
I had a similar problem it was a pinion and spider gear issue
Old Aug 17, 2014 | 9:44 AM
skruzich's Avatar
ABSOLUTELY! its most likely one of the calipres are frozen and bad. Replace calipers and brake pads and make sure to turn the rotors as well.
they are around 42.00 each, might be cheaper where you are. REPLACE BOTH rear calipers, pads and turn rotors. IF this has drums which it shouldn't if its a 98, turn drums and replace shoes and the piston at the top where it pushes the shoes against the drum.
I Think it is rotors though and you just need to replace them.
That growling sound could be also that you have ground into the rotors with the rivets in the brake pads. Replace rotor if it can't be turned and when you buy pads, buy bonded pads not riveted pads.That will save you money in the long run.
Old Aug 17, 2014 | 8:51 PM
skruzich's Avatar
My uncle whos a master mechanic says it sounds like pinion gear bearings in the differential
Old Aug 18, 2014 | 4:53 AM
expensive to fix?
