S-10 & Blazer 1982-2005
Problem with my 2.2
Old Dec 20, 2007 | 1:38 PM
cts 96 2.2's Avatar
Default Problem with my 2.2
I have a 1996 sonoma 2.2l. the engine has no power and stall around 3500 prm. I have replace the cat. converter, tps, map, iac sensiors. I am stumped. can anyone help?
Old Dec 20, 2007 | 1:45 PM
EvansBlue's Avatar
Default RE: Problem with my 2.2
Yes. Take off the intake and if you see oil, replace the PCV valve.
Old Dec 21, 2007 | 10:14 AM
cts 96 2.2's Avatar
I have replaced the PCV valve and the intake and no oil alot of carbon build up.
Old Dec 21, 2007 | 11:52 AM
EvansBlue's Avatar
how bout the O2 sensors?
Old Dec 26, 2007 | 8:55 AM
cts 96 2.2's Avatar
If the o2 sensors were bad would it kick out a code?
Old Dec 26, 2007 | 1:30 PM
EvansBlue's Avatar
Yes, it will kick out a code. It also detects if the system is running too lean or too rich, and if it runs too lean for too long or too rich for too long, the computer may try to override the code, thus causing the vehicle to lose power.
Old Dec 27, 2007 | 10:54 PM
aj_wicked13's Avatar
I am assuming you did a full tune up on this thing? do you have a vacume leak anywhere? How about the Timing? do you know if the computer is advancing or retarding the timing as it needs to through out the power band? Have you checked compression? maybe you have a major compression loss in a cylinder. If you can check the coil output. make sure you are getting a good strong spark. other than that i don't know. you could also take the intake off and take it to a shop and have it "steam cleaned"(I would find a shop to do it before pulling the intake though)... I used to work at a ford dealership and we had this heated power parts cleaner that i put my intake in.... It removed all signs of carbon build up.. It looked like a brand new intake from the dealer. anyways it increased my power a good bit as well as drivability. That was a 4.3 but i would assume you could get similar gains from a 2.2. Check your injectors. I don't know how the fuel injection is set up on those but if its TBI you could only have 1 injector firing. And on that note dont forget about the fuel filter. It only cost like 10 bucks and is cheap insurance to any problems. and on the fuel sysem note check fuel pressure.
Rosariods
Jul 21, 2011 8:13 PM
BayAreaChevyGuy
Jan 6, 2011 2:27 AM
chenzo
Mar 21, 2010 5:35 PM
99silver
Feb 2, 2008 4:14 PM
Yesi
Oct 8, 2006 6:27 AM
