S-10 & Blazer 1982-2005
Project S10
Old Sep 3, 2019 | 11:05 PM
Dennis Helton's Avatar
New User
Awaiting E-mail Confirmation
Default Project S10
I've got an 88 S10 with 4l60 2wd I've changed the ujoints and differential axles looked fine diff was ok I'm still getting the clunk going into drive I'm curious if this is from the tailshaft trans shifts fine goes down the road smooth coming to a stop I get a popping noise depending on how consistent braking is and when going into drive I get the clunk
Old Sep 4, 2019 | 7:19 AM
Did you grease the slip joint?
Old Sep 4, 2019 | 5:31 PM
New User
Actually I didn't know this but I did some research and found that this is actually quite common The GM drivetrain clunk. I did not grease the slip yoke I will be though thank you for your response Old Chevy I appreciate it
Old Sep 4, 2019 | 7:03 PM
New User
Ok I greased the slip yoke still got the clunk I noticed when doing this that the slip yoke will go on no matter the position of the slot I'm beginning to believe the output shaft need replacing
investbo
Feb 6, 2020 11:41 AM
JimNC9
Aug 3, 2011 10:45 PM
vetsir
May 4, 2010 11:44 AM
Outcastz89
Nov 30, 2007 12:10 AM
dragonrpc
Jan 8, 2007 3:06 PM
