S-10 & Blazer 1982-2005
Questions
Old Aug 17, 2015 | 6:09 PM
MrRoboto's Avatar
Default Questions
Hi I picked up a 200 Blazer and have some questions. I picked this up as something fun to work on, but not really familiar with GM to much.
Fuel Pressure Test revealed 60PSI during pump run, 50 PSI drop off right after pump stops, then bleed off. So Is the speck for this 62PSI min pressure at all operating conditions? Seems to have some conflicting info
Vehicle will not start, but unsure if there are mechanical issues or not.
Also, found this at the bottom of the tank. Any Ideas?
Thanks!
Mystery Part
Old Aug 18, 2015 | 10:29 AM
Richardx2's Avatar
That is part of your fuel pump unit. I am not sure on the pressure specs for the pump.
spddmn713
Aug 24, 2006 5:26 PM
SUPERCHIPS TUNER
Jul 20, 2006 11:48 AM
Z Factor
Jul 2, 2006 5:07 PM
five0_4tluv
Apr 26, 2006 12:59 AM
TP
Apr 26, 2006 12:42 AM
