S-10 & Blazer 1982-2005
rear driver brake wont bleed
Old Jun 2, 2015 | 8:37 PM
blazerhazer's Avatar
Default rear driver brake wont bleed
I just replaced the rear brake line on my 99 s10 blazer. The rear passenger side bled just fine, but the driver side will only let out a few drops even after over an hour of trying. We unhooked the end from the abs unit and tried to bleed out that,but there is still no pressure and the peddle goes to the floor. Help pleaase. Thank you
Old Jun 8, 2015 | 9:19 PM
S10forever's Avatar
HI,I just did a brake job on my 94 sonoma and the same type of problem finely took the bleeder screw out and found it was plugged up,cleaned screw,stepped on brake pedal and got clear fluid and put back together and got good stream out of bleeder screw.
tbb2
Aug 4, 2015 11:23 AM
shanedaff
Mar 27, 2015 11:25 AM
300winchester
Jan 8, 2010 10:36 AM
Waltmoe
Aug 31, 2007 11:33 AM
chevy3quarta
Jul 27, 2007 5:19 PM
