Rewiring Spark plugs problem 02 blazer s10
I replaced the cap and rotor, removed the plugs 1 at a time and replaced them at .060 gap and now its not running very good at all, was running better before i did the work. I think I might have got the wires out of order, does anyone have a diagragm for me that i can see, I have no manual, and cant seem to find one on line. Any help will be appreciated. thanks, Rick
RE: Rewiring Spark plugs problem 02 blazer s10
I can't find a pic of the distributor, but I did find a firing order. Line up the motor to TDC on the compression stroke for cyl #1. Take the cap off, and where the rotor is pointing, that spot on the cap is 1. Firing order is as follows, 1-6-5-4-3-2. So going in a clockwise direction, where the rotor is pointing is 1, the next one is 6 and so on
I have the firing order and the distributor diagram:
EDI ignition
Rear of engine
Distributor Diagram:
----(6)--(5)----
---(4)----(1)---
----(2)--(3)----
Engine Diagram:
(6) (5)
(4) (3)
(2) (1)
Just line up the wires with the correct numbers above.
EDI ignition
Rear of engine
----(6)--(5)----
---(4)----(1)---
----(2)--(3)----
Engine Diagram:
(6) (5)
(4) (3)
(2) (1)
catill
August 30th, 2010 11:07 AM
