S-10 & Blazer 1982-2005
Rewiring Spark plugs problem 02 blazer s10
Old Apr 7, 2008 | 7:23 PM
rlk3259's Avatar
Default Rewiring Spark plugs problem 02 blazer s10
I replaced the cap and rotor, removed the plugs 1 at a time and replaced them at .060 gap and now its not running very good at all, was running better before i did the work. I think I might have got the wires out of order, does anyone have a diagragm for me that i can see, I have no manual, and cant seem to find one on line. Any help will be appreciated. thanks, Rick
Old Apr 8, 2008 | 4:58 PM
shawnvw's Avatar
Banned
Default RE: Rewiring Spark plugs problem 02 blazer s10
I can't find a pic of the distributor, but I did find a firing order. Line up the motor to TDC on the compression stroke for cyl #1. Take the cap off, and where the rotor is pointing, that spot on the cap is 1. Firing order is as follows, 1-6-5-4-3-2. So going in a clockwise direction, where the rotor is pointing is 1, the next one is 6 and so on
Old Apr 8, 2008 | 8:07 PM
EvansBlue's Avatar
I have the firing order and the distributor diagram:
EDI ignition
Rear of engine
Distributor Diagram:
----(6)--(5)----
---(4)----(1)---
----(2)--(3)----
Engine Diagram:
(6) (5)
(4) (3)
(2) (1)
Just line up the wires with the correct numbers above.
bizkit64
Nov 15, 2015 6:29 PM
Space Dandy
Nov 5, 2014 7:18 AM
chev3500
Mar 15, 2011 6:51 PM
catill
Aug 30, 2010 11:07 AM
