S-10 & Blazer 1982-2005
S10
Old Apr 1, 2008 | 7:37 PM
ronio's Avatar
Default S10
hi chevy fans.....
did somebody know where is the temp sensor of my S10 1998 4 cyl 2.2l
i'm looking for it because the temp gauge doesn't work..
i hope the get a answer so i can fix it soon.
thnxs buddy's
Old Apr 1, 2008 | 7:44 PM
shawnvw's Avatar
Banned
Default RE: S10
This should get you started:
The temperature gauge is an analog device that is located in the IPC. The temperature gauge is operated by the IPC with software control. The VCM/PCM uses Class2 communications in order to inform the IPC of the engine coolant temperature. The IPC operates the Temperature Gauge to appropriately display the engine coolant temperature. The VCM/PCM determines the coolant temperature by measuring the current from a variable resistance sensor in the engine coolant jacket with the ignition switch in the RUN position. The sensor changes resistance with the coolant temperature. As the coolant temperature increases the resistance of the sensor decreases. The coolant temperature sensor (CTS) is located in the thermostat housing on the 2.2L engine. The CTS of the 4.3L engine is located on the left side of the cylinder head
Old Apr 1, 2008 | 7:54 PM
ronio's Avatar
Default RE: S10
hi my friend
i will just say you thnxs my friend for your help!!!!!!!!!
appreciate that buddy...
nab_pwner
Apr 16, 2022 12:02 PM
Fliver
Jan 28, 2016 9:12 PM
fastfirebird
Nov 10, 2006 5:20 AM
