S-10 & Blazer 1982-2005
should i swap my 2.2 motor for a 350 built to 400hp
Old Jun 28, 2007 | 5:39 PM
J DuBz's Avatar
Default should i swap my 2.2 motor for a 350 built to 400hp
i have the 2.2 in my truck right now and my neighbor has a 350engine that he rebuilt and it has around 400hp.. wat do i need and how much would it cost to do the swap.. as of right now my truck has a body kit and is lowered to the ground so i dont no wat to do wat do u guys think i should keep it for looks or drop the 350 in it
Old Jun 28, 2007 | 8:32 PM
nrf911's Avatar
Default RE: should i swap my 2.2 motor for a 350 built to 400hp
putting in the 350 is gonna cost alot and will entail lots of work. It will need a conversion motor mount kit (available through summit racing) and probably a different transmission (depending on your gearing) also if your truck sits too low with the 2.2 then it may sit much too low with the 5.7 (350) you might look into a stronger more stiff shock in the front end. Otherwise the motor will add power to compliment the looks so by all means carry on with the install.
tech180
Jan 31, 2013 4:25 PM
vettegofast
Jun 2, 2005 5:06 PM
