S-10 & Blazer 1982-2005
stalls on take off
Old Mar 16, 2008 | 10:46 PM
kenehsr's Avatar
Default stalls on take off
I have a 93 s-10 with a 2.8 v6 w/tbi and 5sp trans. It will run fine at idle all day if you let it, but as soon as you take off it loses power and starts to stall. The fuel pump was replaced about a 1yr ago. I thought it might be bad gas so I drained the tank and replaced the fuel filter. Put in fresh gas and a gas additive. The spark plugs, plug wires, dist cap and rotor button was replaced about 3 months ago. I have also replaced the ignition coil and the O2 sensor. I'm still having the same problem. When I ran test on the computer it said to replace the o2 sensor. Which I did and it ran fine for half a day and started acting up again. Now when i run a test on the computer it tells me nothing is wrong. I've also tried a second computer and still get the same thing. Not sure what is left. Any suggestions would be very helpful. thank you.
Old Mar 25, 2008 | 11:03 AM
ddover's Avatar
Default RE: stalls on take off
my 91 is doing the same thing if anyone replys to mine I will let you know
Old Apr 11, 2008 | 11:19 AM
kenehsr's Avatar
Thank you ddover. I still haven't fixed it yet.
This is what i have done or replaced
Replaced O2 sensor, ingnition coil, TPS, vacuum lines, drained the gas tank, new fuel filter, rotor button, dist cap, plugs, plug wires, reset the timing, and tried another computer.
The truck will set at idle ok. It is when you start to take off it bogs down and starts to stall. Now cold or hot. When I tried the other computer I reset it so if it had any stored codes I would get confussed on which error codes where mine. So now when I run it to get the error codes it doesn't show any. It just flashes code 12 which is diagnostic mode, so it is acting like there is nothing wrong. Could there be something wrong with the tbi or map sensor? I would be very thankful for any input.
Old Apr 11, 2008 | 3:46 PM
rabbit0102030's Avatar
Former Moderator
Honorably Retired Member of Staff
Try a search on "s10 fuel pressure", there are some good threads in there that might give you fresh ideas.
Oh and have you changed the fuel pressure regulator? .......or checked the pressure for that matter.
Old Apr 14, 2008 | 1:39 PM
kenehsr's Avatar
Thanks rabbit0102030 for the advice and no I haven't checked the fuel pressure. The guy I got the truck from said he replaced the fuel pump about 2years ago.I'm going to buy a gas pressure gauge to check it. I'm also think of rebuilding the tbi unit. Again thanks for the comments.
tom5170
Mar 16, 2010 9:41 PM
jhsands
Jun 22, 2007 8:24 PM
rhathaway
Jun 9, 2007 8:06 AM
