S-10 & Blazer 1982-2005
starting and dieing issue
Old Jun 6, 2011 | 10:48 AM
dabruguy's Avatar
Default starting and dieing issue
hey need a little help.... got a 96 S-10 4.3L....75,000 miles
it recently died and wouldnt start....replaced the Fuel pump and the Fuel Pump relay (glovebox) now it starts right up and runs but it dies after a few minutes, it will start right up and run again tho...
I am wondering if I am missing something
Old Jun 12, 2011 | 4:41 PM
dabruguy's Avatar
Default s10 starting and dieing issue
I have also just replaced the Ignition Control Module and it started....but died 10 minutes later,,, then replaced the ignition coil, no start,,,and seeing I had a rotor and dist cap (new) I installed them to
so now I have replaced the fuel pump, fuel pump relay, ICM, coil spark plugs, spark plug wires, distributor cap and rotor... have 60 psi fuel pressure
Old Jun 17, 2011 | 3:02 PM
dabruguy's Avatar
Talking Found the issue
well....after much reading and researching and testing and testing....
we went out and got a Crankshaft Sensor Module/switch.... took out the one 10mm bolt reinstalled the new switch whallaaaaaa
truck started and runs great
why didnt that throw a "CHECK ENGINE LIGHT"
Kodytruckguy
Dec 2, 2014 5:59 PM
TRX450R
Jan 7, 2014 3:18 PM
ladeedawdeedaw
Dec 6, 2010 9:32 PM
mikec0777
Sep 13, 2009 7:10 PM
cgtaj1
May 13, 2008 9:41 AM
