starting issue with my 01 blazer
I have a 01 chevy blazer with 140,000 miles. Lately it has been starting hard in the morning. I have to turn it over about 3-5 times befor it will fire, and within those time it will barely start to run but then shut down. after that first start that it will fire right up unless it sits for a few hours. Plugs and wires are probably about 2 years old. distrbutor cap is about a year old and fuel pump about two years old.. and fuel filter just got replaced like two months ago. anybody have a clue on whats going on?? I really dont want to spend a ton of money just to find the problem.
If the manifold is holding pressure the pump will should run for 2 seconds at key ON. Next time engine is cold turn key to ON for several seconds before trying to start.
An alternate test ... if there's a fitting on your fuel rail, you could ... using great caution (cover with a rag) ... relieve the fitting to see if fuel is forcefully expelled.
I was just thinking ... the PCM may limit fuel pump cycle to 2 seconds ... if it runs and stops, you might turn key OFF and back to ON two or three times to ensure the fuel rail is pressurized (55 - 60 psi).
What kind of miles do you have on your two year old tune up?Your plugs wires and distributor cap and you did replace the rotor when you did the cap right?What about the air filter is it maintained ?
