S-10 & Blazer 1982-2005
sticking brakes
Old Aug 23, 2013 | 7:45 AM
thomis's Avatar
Default sticking brakes
I'd be grateful for some advice here, fellas.
I have a '98 2-door S10 4X4 Blazer with 209k miles. She purrs like a kitten <most of the time>.
Recently I've been having some problems with the brake calipers sticking. It doesn't always happen though. About a month ago I pulled off the front wheels and greased the caliper pins on both sides. It is back to pulling to the right when I hit the brakes. Yesterday, the left front brakes stuck so hard they were smoking when I got home. I know that grease couldn't have worn off in a month's time so I am suspecting there might be a different cause. Can someone shed some light here?
Many many thanks!
Old Aug 24, 2013 | 4:52 AM
Headache Ball's Avatar
Sounds as if your rubber brake lines are bad. They can collapse on the inside and hold pressure/ not relieve pressure in the caliper. Calipers wear out, too, and you have a pile of miles...
Toddbrandon28
Mar 24, 2014 6:39 AM
fireman45
Mar 27, 2011 10:43 AM
oneStickySilverado
14
Dec 15, 2010 2:40 PM
UnRumble
Feb 15, 2010 11:53 PM
linerunner
Dec 12, 2006 5:15 PM
