S-10 & Blazer 1982-2005
tbi to carb 4.3
Old Mar 24, 2019 | 6:27 PM
  #11
Irish_alley's Avatar
I'm here for the party
should be tan/white or a gray wire
Old Mar 24, 2019 | 7:13 PM
  #12
oilcanhenry's Avatar
Originally Posted by charlie2sods
i will soon be 74, i want an old school truck that I understand and can work on, thats the shortest best answer i can give
I understand. I am old-school in many ways too, and I get that you understand carburetors. Have you considered a Holley two-barrel carb instead of a ford/autolite two-barrel carb? Holley makes great carbs. I should know, as I have overhauled many carbs in the past and I trust the Holley brand. Easy to work on and they are very reliable. This would be what I would choose if I went back to a carbuerated motor in a two barrel version. Comes with a 12 volt electrical choke too:
https://www.holley.com/products/fuel.../parts/0-80350
Either way, good luck on your new project.
Old Mar 24, 2019 | 8:49 PM
  #13
charlie2sods's Avatar
this one has a 12 volt choke, and i got it on there already just not sure about the two vacuum lines, the one in the right rear base 3/8 and the one in front of the choke 3/16, im thinking the small one goes to the distributor and the one in the rear is the pcv but i need to make sure
Old Mar 24, 2019 | 8:50 PM
  #14
yes gray at the relay tan at the back, thanks
Old Mar 24, 2019 | 9:26 PM
  #15
I think you are correct. The sizes sound correct to me. If you have a vacuum advance distributor then the 3/16" th hose sound right, same with the 3/8" inch for the PCV hose.
Old Mar 29, 2019 | 6:30 PM
  #16
i got the pump out of the tank waiting on a pump, carb on, new hei distributor with builting coil, all wired up and ready to try and fire after pump arrives but i have a question for those who know, on the old distributor there was a small plug that went to one side of the distributor, not the one from the coil, it is smaller and i think it has four wires, is there anything in those 4 wires that I need to be concerned with, all the sensors are gone, im not sure about this plug and wires, any help would be appreciated
Old Mar 29, 2019 | 8:47 PM
  #17
This wiring diagram should help you discover which wires you are concerned about:
https://wiringforums.com/chevrolet-h...iring-diagram/
Old Apr 3, 2019 | 1:43 PM
  #18
the vent line from the tank to the purge cannister, and then a line was hooked into the throttle body best as i remember, now that I have a carb on there what should i do with that line, anyone have any ideas, thanks, i got it converted and running just finishing it up. does anyone know what the idle vacuum should be on this engine with a carb, thanks
Old Apr 3, 2019 | 7:12 PM
  #19
Depends on timing, compression but I'd guess 17-21 pounds of vacuum idle.
Old Apr 3, 2019 | 9:06 PM
  #20
i got 18-20 so i guess its ok, i got a new 2100 motorcraft carb on this 4.3 and it has a little hesitation when you start to open it up, i havent got that figured out , but i got it running, just need to get a hot wire from the switch for the electric fuel pump, and then i will have my old school truck no puter, no sensors.
