S-10 & Blazer 1982-2005
timing help
Old Jun 20, 2013 | 8:32 PM
mirandaneon's Avatar
Default timing help
well i can get it to run but not right, i set it at tdc (compresson stroke) and then set dizzy to 1 and it wont start,
if i turn it a lil it will start so the dizzy has to be on 6 (and the engine set to tdc)and that puts my timing tab in between the timing marks.
then i plug in the wire in the pass side floor board, and then it seems to move the timing mark to were the first one is just after the timing tab.
i also checked and the CS pulley hasn't slipped or sheared off the key. and i changed the head gaskets, that's what got me here. its really funny, cause before, i had done the timing no prob.I just set it to the second timing mark, set dizzy to one cranked it and it fired right up i dont even remember setting it to the compression stroke honestly. but right now the compression stroke at tdc DOES NOT LINE UP TO A TIMING MARK, it sets me in between the 2 and it runs fine but it cranks wierd and sounds hard.
what do i do now?
jmms
HHR
Apr 17, 2015 4:22 AM
nashcarjay
Mar 11, 2012 5:42 PM
lowendtorque
May 27, 2008 8:20 AM
dcskater602
K5 Blazer
Apr 27, 2008 7:41 PM
LetsGoMets78
Cobalt
Dec 18, 2006 2:48 PM
