S-10 & Blazer 1982-2005
trailer wiring
Old Sep 30, 2008 | 9:53 AM
goosegetter's Avatar
Default trailer wiring
have a 97 blazer. it has 7 pole wire harness. the harness runs from the back up to the front by the brake fluid res. what do you hook the electric brake wire to? thanks 4 the help
Old Sep 30, 2008 | 8:42 PM
old dog's Avatar
Default RE: trailer wiring
u will have to hardwire it to the cold side of the brake light switch .,so when you press the brake peddel it make's the wire hot .
Old Oct 1, 2008 | 8:25 AM
old dog where is the cold side of the brake light switch at? I don't nessaralyneed an electric brake controller do i? i know some people use electric brakes w/o brake controller.
Old Oct 1, 2008 | 8:48 AM
old dog's Avatar
there is no way to use electric brake's on a trailer with out a brake control .if you have a trailer that is generally 3500 lb or heaver ,buy law it must have brakes.and there buy you have to have some way to apply them .the only way to not have a controller and use the trailer brake's is to have hydraulic surge brake's on the trailer .
Old Oct 1, 2008 | 1:03 PM
ok where is the cold is of brake light switch located at?
intheknow
Jul 24, 2014 10:38 AM
billhemingway
May 4, 2010 3:53 PM
mgoddard
Aug 2, 2007 4:51 AM
connman119
Aug 23, 2006 9:13 PM
