S-10 & Blazer 1982-2005
Transmission bump
Old Jan 25, 2010 | 4:35 PM
Caldoran's Avatar
Default Transmission bump
I bought my 1996 Blazer a month ago with 240000 miles on it. It drives great. But recently when I go from Park in Drive it 'bumps' in drive. Mostly when I drive it shift smooth but at times while pulling up, it 'bumps' in 2nd or 3rd gear, like something hit the back of the Blazer. My Service Engine Soon light also lights up, but goes off by itself a fter a few days. Any suggestions?
Old Jan 25, 2010 | 4:39 PM
nauticstar87's Avatar
Get the codes ran a Autozone. 240000, is a lot of miles on a transmission. Do you know if it the original trans?
Old Jan 25, 2010 | 5:23 PM
Caldoran's Avatar
Yeah, its a lot of miles, but always good maintained. And no, I don't know if its the original transmission. When I drive in 4W High I have no problems, only in 2W.
Old Jan 25, 2010 | 7:12 PM
I shoulda said this earlier, but check the fluid, is it red, and does it smell like burnt metal??
Old Jan 29, 2010 | 2:37 AM
Caldoran's Avatar
I have an update about the transmission problem. I discoverd that a vacuum hose was disconected from the engine. This didnt solve the problem. I went to Autozone and I have a PO122 code. Can this be the problem with shifting? Also at times when I go to park after driving the Rpm's are going way up. When I restart its normal. My transmission fluid looks normal and doesn't smell to much like metal. So hopefully my problem will be solved with a 35 bucks sensor.
Dave8x
Feb 19, 2011 7:34 PM
mikecwik
19
Jun 10, 2009 9:11 PM
JC10
Nov 26, 2008 4:44 PM
K9Blitz
Jul 4, 2007 10:48 AM
tufftitty
Apr 18, 2007 9:35 PM
