S-10 & Blazer 1982-2005
truck dies at light
Old Aug 24, 2008 | 11:48 PM
bakeradam28's Avatar
Default truck dies at light
i have a 90 s-10 4.3 and cant seem to keep it running at a red light and shakes really bad like mis fire but i have replaced my cap and rotor, my coil and plugs and wires and i can her my fuel pump kick on when starting does any one have a clue please let me know its my only vehicle and i have been standed so much HELP!!!!
Old Aug 29, 2008 | 5:31 PM
bigdirtmcgirt's Avatar
Default RE: truck dies at light
I had the same problem with my 89.
the computer was not working, it wasn't throwing any codes either.
That is the bad thing, you can't tell your computer is going because it
doesn't tell you.
Also check the egr just in case.
Old Aug 29, 2008 | 7:36 PM
05silverdmax's Avatar
try pulling off the egr valve and check to see if it is plugged with carbon,or get ahold of a vacuumpump remove the vacuum line from the egr diaphram and apply vacuum <with engine running> if engine stumbles or stalls its ok if nothing happens its blocked
Resendiz
Aug 4, 2015 11:35 PM
zack3439
Camaro
14
Jul 28, 2015 7:25 AM
Rastaman84
Colorado
Aug 12, 2014 12:40 PM
The Red Tsar
Jul 18, 2014 9:22 PM
stewartj
Dec 14, 2011 5:55 PM
