S-10 & Blazer 1982-2005
Water in the oil after new gaskets
Old May 21, 2008 | 3:09 PM
zygmore's Avatar
Default Water in the oil after new gaskets
Today, after driving around my car, I noticed water had shot out of it. It ended up being a cracked upper radiator hose. Last week I just finished up replacing the head gaskets, and everything has been going fine until today. I checked the oil in it and it turned to sludge again. It's ran fine, and hasn't done this at all till now. It has been perfectly fine until today. Could this be a fluke or could there be another problem with it?
Old May 21, 2008 | 4:25 PM
EvansBlue's Avatar
Default RE: Water in the oil after new gaskets
Could be the head gasket inproperly installed. Could also be that you didn't get all the water out of the oil after the gasket was replaced.
Old May 21, 2008 | 4:47 PM
zygmore's Avatar
Could the head gasket be the only thing, could it maybe be the intake manifold gasket?
Old May 21, 2008 | 5:01 PM
EvansBlue's Avatar
Its a possibility, but it has to be a really bad leak to leak internally into the lifter valley.[/align] [/align][/align][/align]What model is the vehicle?[/align]
Old May 21, 2008 | 6:11 PM
zygmore's Avatar
1996 4.3. The reason I say the intake is I didn't pay as much attention to it as I did the heads when I did the gaskets. Also don't think I put enough rtv on the coolant holes in the gaskets.
Old May 21, 2008 | 6:33 PM
EvansBlue's Avatar
Yeah. Not enough RTV may be your problem. You have to have a pretty thick bead on it.[/align]
Old May 21, 2008 | 7:11 PM
shawnvw's Avatar
Banned
The issue with not enough silicone should only affect oil leaking externally via the valley part of the intake. Or am I missing something? Its been a while since i've done one of these
Old May 21, 2008 | 7:32 PM
zygmore's Avatar
There are 2 coolant holes on each side of the head that dead ends at the intake. My best guess is not a good enough seal around these holes will allow water to seep by into the lifter valley, and effectively into the oil. Also, I can't find my book, so if someone has the torque specs/ tightening sequence on the intake manifold for this model and could post it, that would be great!
Old May 21, 2008 | 8:00 PM
EvansBlue's Avatar
Yeah. Let me find my repair manual...
Old May 21, 2008 | 8:15 PM
EvansBlue's Avatar
< Front of engine
12 5 4 2 7 10
11 6 1 3 8 9
35 ft/lbs (all except bolt9)
41ft/lbs (bolt 9 only)
