S-10 & Blazer 1982-2005
will a transmission form a 04 astrovan rwd go into a 95 blazer 4x4
Old Aug 31, 2009 | 8:46 PM
blimpinainteasy's Avatar
Default will a transmission form a 04 astrovan rwd go into a 95 blazer 4x4
The Transmission in my blazer is starting to have issues and my neighbor recently totaled his astro van that has a brand new transmission in it. I am wondering if I can make it work even if I loose four wheel drive.
Old Aug 31, 2009 | 8:55 PM
MDTAHOE's Avatar
Professional Mechanic
You could do it if you lose the 4 wheel drive. You may have to use his drive shaft or have to have one made. Or I think you could take both transmissions to a trans shop and have them put your output shaft into his trans. The output shaft on 2 wheel drive is longer. The tail shaft is also different between the 2 but that is easily changed with 4 bolts.
Old Sep 1, 2009 | 1:04 PM
myotherchevyisablazer's Avatar
took the words right outa my mouth....x2 for the fix....
Old Sep 5, 2009 | 1:29 PM
Does anyone else find it amusing that when you mouse over the words four wheel drive, it has a jeep advertisement in a Chevy forum?
Old Sep 6, 2009 | 9:25 AM
mudmaniac's Avatar
Ride of the Month
May 2009
It's a conspiracy
bitts
Jun 28, 2012 9:33 AM
mjorg
Aug 22, 2010 10:33 PM
shamcd
Jun 15, 2010 8:41 PM
fpd370
Mar 11, 2010 11:48 PM
TierSpass
Aug 24, 2009 1:03 PM
