S-10 & Blazer 1982-2005
wiper motor possest
Old Feb 7, 2020 | 7:39 PM
thisoldchev's Avatar
Default wiper motor possest
my dad's 03 s10 wipers work sometimes then they go crazy, then they slow down and stop then take off again. moving the inside switch doesn't help. i was thinking of going to the local catholic church to get a priest with some holy water or at least throw a ford emblem on it. or i could take the wiper motor out and try to fix the module. does anyone know where i can get a wiring diagram for the wipers?
Old Feb 8, 2020 | 1:29 AM
oilcanhenry's Avatar
Check your wiper motor relay.
Old Feb 8, 2020 | 6:51 AM
Wiper motor or bind in wiper linkage.
Old Feb 9, 2020 | 12:41 AM
vinman's Avatar
Chevy wiper motors of that period and going back to the late 90's are notorious for acting up for no apparent reason
The problem has been commonly attributed to cold solder joints on the electronic board that is part of the wiper motor
The housing is easily removed while leaving the motor in it's location in most older vehicles that have the motor mounted on the firewall
I think on the 2003 you might have to remove the entire motor
A decent solder iron will fix the solder joints easily
The tube is full of videos on this topic
Cheers ..... Vin
Old Feb 10, 2020 | 8:48 PM
i took the motor out and redid the soldering joints now i just won't shut off. it looks like the pulse board was changed once but they are about 25 bucks and easy enough to put in. where is the wiper relay.
jfischer219
Jun 14, 2019 3:38 PM
dano1
Jun 14, 2015 4:20 PM
wsmutch
Jun 10, 2010 10:17 AM
malibanger
Feb 23, 2009 2:45 AM
Schlickster
Jul 22, 2006 11:19 PM
