S-10 & Blazer 1982-2005
ZR2 Fuel system
Old Nov 9, 2006 | 11:14 PM
Archdawg's Avatar
Default ZR2 Fuel system
I have seen a few posting regarding the S-10 fuel system and am showing signs of trouble with my 2000 4.3L V6. After sitting for 1-hour or so it takes quite a few turns to get the engine started. I have checked fuel pressure on the system just after shutting off the engine and have pressure. I have not checked PSI on the system (don't have a guage). I thought I heard hissing or an air leak near the fuel tank after checking fuel pressure. What could be causing the loss of pressure? I can hear the fuel pump running. Had my electronic ignition replaced 2 years ago. Any ideas?
Old Nov 10, 2006 | 12:54 AM
70mopar's Avatar
Default RE: ZR2 Fuel system
since u haven't mentioned finding any visable leaks, it sure sounds like the pressure is bleeding off the pump. u really should do pressure check on the system when it's off, and check it periodically 2 see if, when, and by how much the pressure drops. just how long do u crank it 4? 1 second? 2...3.....5!?
Old Nov 10, 2006 | 2:31 AM
Archdawg's Avatar
It is a 2 - 3 count before it finally turns over after sitting over night (which is much longer than normal, usually a quick hit of the key fires it up). I agree with you I need to get that pressure tested to see how quickly it goes down after the engine is off. Doesn't the fuel pump initiate when the ignition is switched on? You would think that would sufficiently pressurize the system.
Old Nov 10, 2006 | 10:21 PM
70mopar's Avatar
if the pump is not keeping the pressure up while the truck is parked, the quick pressurization u hear @ start-up is not enough to pressurize the system-remember, the pump could b bleeding off all the pressure in the system. kinda like changing the fuel filter and not getting the new one on & done up right away, so the 1/2 to 1 second prime doesn't fill up the 12 feet (or so) of fuel lines 2 the injectors.
Old Dec 13, 2006 | 1:49 AM
tigertamer's Avatar
If I'm not too late with this, you should also check your gas cap as well. A bad seal on the gas cap could alow the pressure to escape!
Good luck,
Larry
Clearvu1
Oct 21, 2008 10:28 AM
bobbie95poca
Mar 15, 2008 2:07 PM
jffgin
Sep 16, 2007 5:42 PM
Moralszr2
Oct 5, 2005 5:00 PM
