S10 & Blazer DIY and Useful Threads This section is strictly for frequently asked questions pertaining to S10s and Blazers.
2000 S10 ZR5 4.3 Fuel Pump test terminal location?
Old Oct 15, 2022 | 7:37 PM
JCLN's Avatar
Default 2003 S10 ZR5 4.3 Fuel Pump test terminal location?
Hello,
I have the subject truck (it is a 2003 not a 2000). It will not start and I do not think that the fuel pump is turning on. I went out a bought a Haynes service manual for it and it mentions a 'Fuel Pump Test Terminal' which is supposed to be located in the engine compartment on the passenger side.
When I google it, it says that it should be a wire that is capped and does not normally terminate anywhere. The picture in the Haynes manual shows it as a white connector.
I cannot find it. Does anyone know where it is and what it might be hidden behind / underneath? The manual says you can jump the wire to positive and the pump should turn on. I figure I can test the pump and if it does not turn on, then I can go from there.
if I need to replace the pump, is it easier to drain and drop the fuel tank or pull the bed off? If I pull the bed off, I will put an access cover in the bed so I can get to the pump and sender in the future.
Thanks,
Nickbalazs_
Feb 27, 2018 8:47 AM
Jeanette Hamilton
Oct 5, 2013 5:51 PM
rodg67
May 30, 2010 9:03 PM
ashortkid
Jan 4, 2009 2:10 PM
lathman
Dec 20, 2006 10:01 PM
