Sensors by thermostat on 82 S10 2.8
There's three sensors right next to the thermostat housing. I broke one changing my thermostat. Was wondering what it is? I know one is the coolant sensor. But what about the other two. Have looked for a diagram showing what they are but hard to find one for a 1982 S10 2.8 manual transmission.
aluminum heat tube from the exhaust manifold to the air-cleaner inlet nozzle. But lots of vehicle manufacturers did that.
timing advance could cost you power and gas-mileage. I'd at least make sure to insulate any wires or any exposed connections if I were you.
I did find a vacuum diagram. Looks like these 2.8 liter motors used a vacuum advance delay device, like many vehicles did, no matter who made them. Its a small little plastic valve that slows down the vacuum to the ignition advance diaphragm mounted on your distributor for smog. If you want you can run a straight hose from the carb to the timing advance canister, or even a piece of plastic or copper tube to shunt this POS device out. Should have better pickup and power, Just make sure your engine doesn't have any knock (it likely won't). We used to bypass these things all the time back then and run the ignition timing up as high as it would go before any knocking occurred. Worked real good for more HP
Can you trace the vacuum hoses back to origin? I am quite interested in this issue. Sure glad new high HP F-I engines that don't have all that c**p, and don't need all those stupid old smog-control devices, like smog pumps, and all the vacuum hoses and wires and other make-shift gimmicks, that the US vehicle manufacturers had to use to pass all the smog laws, way back then.
Pretty sure that one is for your vapor canister. The other one is likely either for the distributor vacuum advance and/or EGR valve. Back then this was used to wait until the engine warmed up to keep emissions system down and the EGR from working,as they had much larger ports back then, and would make the cold engine not run very well Yeah, back then, they used aluminum parts, not plastic, like the replacement unit you would have to buy nowadays:.
shoe1100
Aug 25, 2012 2:37 PM
