03 suburban problem
Old Apr 1, 2022 | 1:50 PM
Winonap's Avatar
Default 03 suburban problem
My 03 suddenly started running bad and would die if you stopped but would crank back up and go so we cleaned out tank and got a new fuel pump and fuel pump relay now it will turn over but won’t crank.I need help
Old Apr 1, 2022 | 2:26 PM
Welcome from Florida. Is the check engine light on? If it is, what are the codes?
Old Apr 3, 2022 | 9:54 AM
pruitt09@att.net's Avatar
Have you replaced the fuel pressure regulator (Simple fix), the diaphragm goes bad in these after a few years, I have replace mine in my 2001 suburban twice now in the past 21 years.
Old Apr 3, 2022 | 11:57 AM
kevinkpk's Avatar
Pull the vacuum line from it, if it has gas, replace it. To the OP, what is the idle rpm's?
Old Apr 4, 2022 | 1:51 PM
Winonap's Avatar
I can’t get it to run it will turn over and that’s it
Old Apr 4, 2022 | 3:17 PM
kevinkpk's Avatar
Pull the vacuum line anyway, if there is gas in it, replace it. Can you put a pressure gauge on it?
rcjunor
Nov 4, 2018 9:25 AM
Curtdiddy Dagreat
Oct 4, 2016 2:43 PM
mtinok
Jun 6, 2011 11:36 AM
jim c
Dec 10, 2009 5:16 AM
krazykris
Jun 7, 2008 4:44 PM
