Help problems with 2008 Chevy uplander
Old Mar 17, 2014 | 1:07 AM
Keithpetriejr's Avatar
Default Help problems with 2008 Chevy uplander
Hi I'm having a problem with my2008 Chevy uplander the daytime lights and washer fluid won't stop running even when it's not turned on
Old Sep 4, 2018 | 1:49 AM
Michael Werner's Avatar
Default Wiring issues
I have an 08 Uplander. It has almost 180000 miles. Lights on the dash includes; ABS, TRAC. CONTROL, CHECK ENGINE, BRAKE also shows the left front tire pressure sensor works when it wants to. Went to AutoZone to check codes. Here are all those.
C0041, C0040, C0267, C0561, C0253, P0315, P0523. I got in it Jan. 2018 the only thing g I have had to do is replace the starter. Unlike most of the post above i have never had the issue of low voltage. But i do have issues with the radio not going off when the key is out of the ignition and the door being open. Also at times I can't unlock the doors from the inside door panel. Everything else works fine. I'm no mechanic and disabled so can't afford to take it to a shop. Any ideas are much appreciated. Thank you in advance Mike
G P Meyers
Uplander
77
Apr 15, 2020 2:37 PM
kimble
Uplander
Aug 4, 2014 8:17 PM
Keithpetriejr
Uplander
Mar 19, 2014 9:39 PM
draysk8
Uplander
Jul 11, 2012 10:33 AM
Pops
Uplander
Nov 20, 2010 10:06 AM
