5.3 misfiring
5.3 misfiring
I have a 2005 Suburban, it has a random misfire code, that comes and goes.
It had the 5.3 flex fuel motor. The motor checked out very good but was down on power. A couple different shops could not correct the problem.
It was missing on 1 and either 2 or 3.
Replaced all the injectors, plugs and the coils on the misfiring cylinders .
The next move I replaced the engine with one out of a pickup, none flexfuel. I transferred everything over with the replacement engine. Coils, Injectors and everything associated.
I then had another shop go over it again checking all the grounds.
It still has the misfiring.
I am down to replacing the computer.
Can anyone give me any suggestions on how to fix the problem?
Duke silver
I had the same issue. I did everything he did but also changed out the wires , that he didn't mention. My issue went away. As far as loss of power, my knock sensors were bad too. Once I did those, power was back in force.
Shooty
August 20th, 2006 5:08 PM
