5.3 misfiring
Old Mar 31, 2023 | 6:51 PM
Policy Peddler's Avatar
Default 5.3 misfiring
I have a 2005 Suburban, it has a random misfire code, that comes and goes.
It had the 5.3 flex fuel motor. The motor checked out very good but was down on power. A couple different shops could not correct the problem.
It was missing on 1 and either 2 or 3.
Replaced all the injectors, plugs and the coils on the misfiring cylinders .
The next move I replaced the engine with one out of a pickup, none flexfuel. I transferred everything over with the replacement engine. Coils, Injectors and everything associated.
I then had another shop go over it again checking all the grounds.
It still has the misfiring.
I am down to replacing the computer.
Can anyone give me any suggestions on how to fix the problem?
Old Mar 31, 2023 | 7:24 PM
kevinkpk's Avatar
I am down to replacing the computer. There you go, the ecm will have to match the physical engine.
Old Jul 31, 2024 | 1:37 PM
DukeSilver's Avatar
Ever figure out the issue?
Old Aug 2, 2024 | 1:48 PM
JoeyDM99's Avatar
Default Duke silver
I had the same issue. I did everything he did but also changed out the wires , that he didn't mention. My issue went away. As far as loss of power, my knock sensors were bad too. Once I did those, power was back in force.
Old Aug 2, 2024 | 8:29 PM
DukeSilver's Avatar
So far I've changed the coils, plugs, and wires. cleaned the throttle body and MAF sensor. I did check the compression too and the numbers came back good.
A code recently popped up for the knock sensors so that's on my list of things to fix. I think I am going to have to change the fuel injectors too because I know my cats are going bad and they might have been the culprit. I have the rotten egg smell from time to time and the cat rattling/vibration noise.
Policy Peddler
Mar 31, 2023 6:53 PM
stannt
Avalanche
Mar 18, 2022 2:03 PM
kmcdowell
Jan 4, 2018 2:25 PM
Rael Ayotte
Oct 23, 2013 1:35 PM
Shooty
Aug 20, 2006 5:08 PM
