How do I fix DTC P0452, P0446, P0449
Old Oct 22, 2023 | 7:14 PM
Mikecoolguy17's Avatar
Exclamation How do I fix DTC P0452, P0446, P0449
New Here Just Bought a Savana Cutaway
Hello everyone So i have a few questions. I bought a used 10ft U-Haul. I got it off marketplace for 500 bucks. It has the 4.8L I have a few codes. Hope someone can help me I have been trying to do research and it's all very confusing. So here is the list.
P0452, P0446, P0449. I have checked the gas cap I know there are a bunch of solenoids and all. I'm not sure where they are all at. So if maybe someone can help me would be great thank you.
Old Oct 22, 2023 | 8:16 PM
Originally Posted by Mikecoolguy17
New Here Just Bought a Savana Cutaway.
what's the year and miles please?
what are the full codes with meaning please? You can look them up on obd-codes.com
Old Oct 22, 2023 | 9:18 PM
hello its a 2003 GMC Savana with 162,000 miles 4.8L and its a box truck Thank you.
Old Oct 22, 2023 | 10:10 PM
sounds like you're referring to the EVAP system. Check for leaks with a smoke machine. vent and purge valves are usually connected to the charcoal canister near the fuel tank.
Old Oct 22, 2023 | 10:13 PM
Do you know where I got under there and couldn't really find anything are they all related to the evap system? I did check all the lines for vacuum and they looked good maybe some pics I know there is something on the engine that might need to be replaced as well. Thanks for the help
Old Oct 22, 2023 | 10:35 PM
How EVAP works
https://www.aa1car.com/library/evap_system.htm
https://www.agcoauto.com/content/news/p2_articleid/294
Old Oct 22, 2023 | 10:38 PM
I saw this video but I have a savanna van or a express and thought it was on a different place I think I need 3 items to clear these DTC codes thank you
Old Oct 22, 2023 | 10:43 PM
what you need is to diagnose the issue
Old Oct 23, 2023 | 6:15 AM
So I understand I need to diagnose the issue but this doesn't help telling me where the parts that would need to be replaced are as different models different things I don't know what all sensors I need to check to replace them...... Was hoping someone else had these issues could help out. Thanks
Old Oct 23, 2023 | 1:44 PM
so the first two links I posted explain how the system works
Did you look near the fuel tank like I suggested? The charcoal canister is hard to miss. From there you can follow the hoses and locate the valves.
Between the three videos you should be able to figure out how to diagnose the issue. The other link I gave you (obd-codes.com) also explains how to diagnose.
If you have any specific question then post them here and I'll do my best to help.
lph008
May 22, 2014 8:55 AM
Debbey Mack
10
Jan 5, 2013 7:16 PM
b_sikes07@msn.com
Dec 9, 2010 11:22 PM
newmonte06
Oct 12, 2009 2:08 AM
two slow
May 19, 2007 10:43 AM
