Chevrolet Avalanche
Platform: GMT 805 & 900
2011 Avalanche - Wheel Delamination
Old April 20th, 2024, 12:05 PM
toddrun's Avatar
Default 2011 Avalanche - Wheel Delamination
Hello All,
I have a 2011 Avalanche, I live in MN, so lots of winter road chemical, combined with the crimp on wheel weights, I have terrible clear-coat de-lamination on my wheels. One wheel is so bad, it continuously leaks pressure, I have to check it weekly, and top is off. Been looking at the option to have the refinished, powder coat painted, and aftermarket wheels or OE replacement wheels.
The issue I am finding is the 31mm offset on the wheels, hard to find aftermarket matching that offset. I put Michelin tires on recently, 13 ply, because I pull a heavy trailer occasionally and I found a great price. Problem is they were 275/65/18 instead of the stock 265/65/18, and on tight turns they do rub on my mud flats slightly. So, if I use an wheel with LESS offset than 31mm, it would make it rub worse and the wheel will stick out further. And finding a wheel with more offset is hard. Also, seems aftermarket wheels have a lower load rating.
Anyone run into this? Find any good aftermarket solutions? Or is OE replacement the best solution?
Thanks
Old July 11th, 2024, 1:18 PM
Crescent-Sal's Avatar
You can visit this site to get the best aftermarket wheels for your 2011 Avalanche.
MCF34
December 14th, 2007 9:07 PM
LiveHuge
August 3rd, 2007 5:39 PM
dogger37
December 5th, 2006 3:44 PM
Quick Reply: 2011 Avalanche - Wheel Delamination
