Steering problem Help!!!
I bought a 2006 silverado 4x4 a few weeks ago. Replaced the tie rods, ball joints, upper control arms, pitman and idler arm.
after installing everything, the inmer tie rod is making contsct witt the cv shaft mount. And the center link is hitting the pumpkin where the fill port is. The inly thing i can see is that the passenger side of the center link is higher than the driver. And the moog pitman arm isnt seating all the way up. I am at a total loss.
1/2 , 3/4 or 1 ton? Engine? quadrasteer?
Check your Z trim height against specification.
procedure for checking Z trim height: https://charm.li/Chevy%20Truck/2006/...n%20Procedure/
1/2 ton. 5.3l. And no quadrasteer.
would the Z height have any affect on the center link in relation to the differential?
on a 1/2t with independent suspension, no probably not.
That was a typo on my part, 6536 is the correct number for the pitman arm I have.
as far as the UCA’s, the website had them part numbers listed incorrectly on the listing. I looked at the UCA’s themselves and the part number stamped on them is CK80942
brunder
June 1st, 2024 6:40 PM
Weller41
1988 - 1998 (GMT400)
December 31st, 2019 12:36 PM
