Venture 1997-2005
Platform: U-Body
Stabilizer bushing/bracket all-in-one?
Old June 23rd, 2024, 11:32 AM
Apache23's Avatar
Default Stabilizer bushing/bracket all-in-one?
Is there a such thing as a stabilizer/sway bar bushing and bracket, that are made together, for any vehicle? In other words, you can't just replace the bushing, because it does not separate from the bracket. Is that a thing? Thanks!
Old June 23rd, 2024, 11:01 PM
post your vehicle info please, and what is the problem you are experiencing?
Old June 24th, 2024, 12:01 AM
Apache23's Avatar
1995 Trans Sport 3.1l TBI. Trying to put new sway bar bushings on it and the bushings that all the auto parts stores have are too big. The sway bar is 1 1/32", except for the last 3" on either side (which is where the bushings go). The last 3" is a little less than 7/8". And when i got the old bushings off, it was like the bushings and brackets were one piece. I had to use a MAP gas torch to burn the bushings out of the brackets. It was very strange!
New bushing is too big
End of sway bar, where it is a smaller diameter
Only way i could get the old bushings out of the brackets
Old bushing and bracket
Old June 24th, 2024, 1:09 AM
Reuse the steel bracket. Once you bolt it down it will close the gap.
09silverado6468
2007 - 2013 (GMT900)
April 12th, 2024 6:46 PM
stilllearning6
April 23rd, 2021 6:09 AM
Tom Colson
December 19th, 2020 10:20 AM
curtis1512
December 11th, 2017 10:02 AM
RockVegas
August 31st, 2013 5:08 PM
Quick Reply: Stabilizer bushing/bracket all-in-one?
