Permanent P0A00 code?
Old July 7th, 2024, 1:41 PM
Jeremy66's Avatar
Default Permanent P0A00 code?
I have a 1997 Silverado 5.7L 4x4. It is throwing a permanent P0A00 code even after replacing the ECT sensor. You can clear the code and reset computer but it still read Permant P0A00 as soon as you scan with a scanner.
Old July 7th, 2024, 11:38 PM
that doesn't appear to be a valid trouble code for your truck: https://charm.li/Chevy%20Truck/1997/...Code%20Charts/
Try a different scanner.
What does your temp gauge say?
Old July 8th, 2024, 6:58 PM
Jeremy66's Avatar
Default P0a00
The code stated P0A00 Motor electronics engine coolant temp. On multiple scanners. Ever if you clear all codes then it reads this code without ever cranking the vehicle and says permanent P0A00 code. I’ve replaced both ECT sensors one for PCM and the one for the gauge. I’ve checked all wires everything is fine. Temp reads fine in scanner but reads high on gauge. I drive the truck 1.5hrs to work and it never runs hot I never have to add water or anything.
Old July 8th, 2024, 7:01 PM
Jeremy66's Avatar
Old July 8th, 2024, 7:24 PM
From service manual
troubleshooting: Temperature Gage Indicates Hot:
https://charm.li/Chevy%20Truck/1997/...dicates%20Hot/
jfmorris (July 10th, 2024)
favio
May 26th, 2024 3:10 PM
poopster
Site Feedback
April 23rd, 2023 12:53 AM
Jeroen
Site Feedback
November 16th, 2019 11:23 AM
Momslilangel
January 30th, 2012 5:20 AM
Quick Reply: Permanent P0A00 code?
