2003 Chevy Silverado 1500 door handles with locks
![Question](https://chevroletforum.com/forum/images/icons/icon5.gif)
I just bought 2003 Chevy Silverado 1500 extended cab, Both exterior door handles are broken. I need to buy new exterior door handles with locks. The ignition keys do not fit the door locks. I thought I found them on E- Bay but they say they only fit 2007 Silverado, so can anyone help me find the right ones to buy?
It looks like you need 2 separate components. One the door handle and Two the actual door lock cylinder. Rockauto.com is your friend in this case, Here are two links for you:
https://www.rockauto.com/en/moreinfo...t=1024&jsn=622
https://www.rockauto.com/en/moreinfo...=10007&jsn=639
For repair information go here: https://charm.li/
Good Luck!
Good Luck!
As another follow up, if the key that cranks the truck doesn't fit the door locks, someone has already changed one of those two components out. A replacement lock cylinder will come with its own key I expect. I am sure someone can rekey them to work with your ignition key, but might cost a bit.
gphillips2
January 6th, 2007 4:17 PM
