2003 2500HD BCM issue
I have a 2003 2500HD Siverado reg cab base model, 2 wheel drive, 6L engine. I had the BCM go out. I had it replaced. Then I had to replace the fuse block. When it was programmed, the daytime running lights, interior dome light, instrument cluster dimmer, alternator gauge and my backup rear camera stopped working. I replaced the light switch and nothing changed. The dome light has 6 volts. There is no power at my daytime running lights. The instrument cluster lights are constant on.. I had the try and reprogram the computer. Any suggestions of what or where the issue is?
slash11
September 19th, 2015 5:34 PM
free outlaw vanners
January 26th, 2014 12:01 PM
