1996 C1500 Ran 15 seconds, then died
Old Apr 4, 2026 | 12:32 AM
jfmorris's Avatar
Default 1996 C1500 Ran 15 seconds, then died
Well, my 1996 C1500 5.0L which is basically a spare vehicle these days, with me dreaming of restoring, it, decided to act up for the first time in many years.
I needed to move all the vehicles out of the driveway to make things easier for a furniture delivery to the house, and the C1500 was the last thing in there, closest to the garage. I cranked it up, it ran normally for 10-15 seconds, and before I put it in reverse, it just died. It turns over normally, but doesn't start.
The first thing that comes to mind is sudden death of the fuel pump. The truck is 30+ years old. I went to replace the fuel pump over 20 years ago by pulling the bed, and found that the wires had frayed and literally shorted together inside the fuel tank, and I think we just fixed the wires, separating them and heat shrinking them, and then dropped the original fuel pump back into the tank.
I'll check the obvious things like the fuel pump fuse and relay first, and check for pressure on the fuel rail. And get my wife to crank it while I look for spark on a spark plug wire.
Any other advice? It will sure be nice if I do not need to pull the bed, as that will be a lot more work and I will need help.
Old Apr 4, 2026 | 12:53 AM
Rednucleus's Avatar
Can you hear the pump run when you 1st turn on the key to run position?
Old Apr 4, 2026 | 7:08 AM
jfmorris's Avatar
I could not hear anything in the cab Thursday when this happened, but the problem is when I turn the key to the run position, but not crank, some darned buzzer/chime runs for several seconds, which would totally mask any sound I might here in the cab from the fuel pump. I guess I need to reach in and turn the key from outside the cab so I can drop down and listen quickly, or get my wife to turn the key for me while I am under the gas tank.
Old Apr 6, 2026 | 8:22 AM
jfmorris's Avatar
Well, I had just a few minutes to look at the situation on Saturday. There is most definitely no noise from the fuel pump when the key is turned to the run position, and normally, I know it should run for at least a couple of seconds to pressurize the fuel rail.
I popped the hood to check the relay, and found this. This is not the original relay, as it is not a grey OMRON like the rest of them, so I've apparently replaced this at some point in the past 30 years. Probably 20 or so years ago when I had an issue with the fuel pump wires shorting inside the gas tank (yes - inside the tank!).
This is the bottom of the relay - you can see that one pin has been pretty hot, and that might be dated to when the fuel pump cut out due to a short 20+ years ago... or it could be recent. Who knows?
And here you can see some matching "melt" damage in the fuse/relay box under the hood...
Unfortunatley, there are no other 5 pin relays under the hood to swap with this one - the others of similar size are all 4 pins. So I guess this issue will sit while I go ahead and order a relay AND a fuel pump from RockAuto. If I am lucky, the relay will be it. And if I am not lucky, I'll be unbolting and disconnecting a lot of stuff under the bed, and taking off the tailgate, tail lights, tool box, etc, so that I can get my son and son in law to drop by one day and help me lift and walk the bed off the truck and set it in the garage.
I am lucky that I live in Alabama. If I lived farther north all the bed bolts would be rusted up and likely not removable. As it stands, I did this once, 20 years ago, which I was 40 versus 60, and do not look forward to doing it again.
Sadly this is another knock against the C1500 that my wife wants out of the driveway due to how bad the original paint looks... I am tempted to just start a home paint job of the cab while the bed is off, if I have to pull it.
Old Apr 18, 2026 | 5:22 PM
jfmorris's Avatar
Well, sometimes the simple fix is the fix. I spent $200 at Rockauto on a new Delphi fuel pump assembly, a WIX fuel filter (needs to be changed anyway) and a GM wiring harness end and a GM fuel pump relay.
The low hanging fruit was the relay, so I popped that in not expecting much, and much to my surprise, the truck fired right up!
So now, I get to decide if I keep parts in my garage in case I need them eventually (done this way too many times over the years), or if I can return the other parts (keeping just the fuel filter) without losing a restocking fee.
Old Apr 18, 2026 | 8:07 PM
Rednucleus's Avatar
Glad you found the culprit - IMHO you can never have too many spare parts!!
Old Apr 19, 2026 | 2:33 PM
jfmorris's Avatar
Yeah.... kinda thinking since I want to start "restoring" the truck, I ought to hang onto the parts and replace the fuel pump and truck side of the harness, proactively. I had already planned to make a little 2x4 contraption to help me lift the driver side of the bed using the floor jack, by myself, while leaving the bolts loose but still in on the passenger side of the bed.
The original pump is 30 years old and has served well for 203,800 miles. And my understanding is that sitting and only being driven once a month is hard on in-tank fuel pumps, especially old ones...
Old Today | 7:48 AM
jfmorris's Avatar
As an update, after going through my records for the truck, I found a receipt where I had paid a shop to replace the fuel pump and fuel filter for $568 back in 2018, when the truck had 186,000 miles on it (at 203K). Until I saw that receipt, I had TOTALLY forgotten about that. Anyway, I found that before the return window to Rockauto ran out, and returned the $180 Delphi fuel pump assembly.
sandygerli
1988 - 1998 (GMT400)
May 28, 2017 5:09 PM
samsaridinc1500
Jul 6, 2013 11:09 PM
sawblade
Jul 25, 2010 9:31 PM
weatherman
Jul 11, 2009 1:07 PM
shanepinkfloyd
Dec 29, 2007 2:25 PM
