wheels 09 1500 4x4
Yes, in most cases wheels from different model years will fit as long as they share the same bolt pattern, offset and center bore. That said, offset can vary slightly from year to year and even trim to trim, so it is worth confirming the exact specs before buying. Your safest bet is to match the offset as closely as possible to your stock setup to avoid any rubbing or handling issues. When browsing Chevrolet Wheels specifically, a difference of plus or minus 5mm is generally considered acceptable but tighter is always better. What model are you shopping for? That will help narrow down which year ranges are a safe swap.
twomanyprojects
Jan 31, 2010 3:39 PM
