wheels 09 1500 4x4
Old Apr 30, 2026 | 6:46 PM
richardpoll's Avatar
Default wheels 09 1500 4x4
so I'm looking for a set of original 17" wheels for my snow tires. Will any year fit? Is the offset very different year to year? Thanks
Old Jun 10, 2026 | 2:04 AM
rores's Avatar
Yes, in most cases wheels from different model years will fit as long as they share the same bolt pattern, offset and center bore. That said, offset can vary slightly from year to year and even trim to trim, so it is worth confirming the exact specs before buying. Your safest bet is to match the offset as closely as possible to your stock setup to avoid any rubbing or handling issues. When browsing Chevrolet Wheels specifically, a difference of plus or minus 5mm is generally considered acceptable but tighter is always better. What model are you shopping for? That will help narrow down which year ranges are a safe swap.
the Brain
Jan 26, 2026 8:01 AM
ManWithAVan
Oct 8, 2021 2:57 AM
Julio Gonzalez
Camaro
Jul 31, 2018 9:50 PM
joebudd
Mar 12, 2010 8:50 PM
twomanyprojects
Jan 31, 2010 3:39 PM
