loud grinding noise
Old Today | 8:15 PM
EthanHancock's Avatar
Angry loud grinding noise
I have a 2004 Chevy Silverado 1500 4wd. when I'm driving i hear a slight grinding noise but when the wheel is turned slightly to the left it gets extremely loud. it has a new wheel hub and bearing and i was told by a mechanic that it sounded like a cv axle so i replaced that and it still persists. the truck doesn't even have to be turning its just if I'm very slightly turning the wheel to the left while still driving in a straight line. when the wheel is turned to the left it make a constant grinding noise with a kind of womp womp womp womp. its coming from the front drivers side area and i have no idea what it could be at this point. it seems like it could be a steering component due to the noise getting way worse when the wheel is turning to the left but it also sounds like its coming from a spinning component since the noise gets faster at higher speeds
Old Today | 8:31 PM
Rednucleus's Avatar
Try jacking the left front up and spinning the wheel, see if you can better isolate it
suburbans_are_cool
Apr 7, 2022 5:06 PM
Maikelo
1988 - 1998 (GMT400)
May 26, 2020 7:20 AM
ontheroadagain11
Mar 25, 2013 4:30 PM
Ruinousmanual
Jul 15, 2010 1:39 PM
