error code 0408 fan 1 issue
i have no continuity between positive lead from cooling fan connector to the cooling fan relay,,,,i don't think there is anything between...must be bad connection or broken wire...wiring harness in engine is very difficult to physically trace the wire back to relay...anybody have suggestions...i think lifting up the external fuse box would really help but not sure how to do this.......please help...
cheers, tom
cheers, tom
cheers, tom
cheers, tom
97 cavalier 2.2l.. 12v .power is at the relay....as i said i measured between power line at fan connector and pulled the relay and measured to the slot where the 12v should be at.....no continuity....so...unless there is something between those 2 points it must be a wire or connector(maybe under the fuse box).....if i could lift that fuse box up a bit it would make it a bit easier to trace the wire down to the fan connector...
