Silverado DIY and Useful Threads This section is for Do-It-Yourself articles and other informative FAQ threads. If you would like to submit an article, contact a member of staff!
cam, roller lifters, and heads
Old Nov 24, 2009 | 7:13 AM
chevy327usn's Avatar
Default cam, roller lifters, and heads
im looking at putting a mild cam and roller lifters on my 5.3 i have also heard that i could put the heads off a 6.0 and onto my motor. i was just currious to see if anyone knew of someone thats done this, or has something similar done to there truck. i had a mechanic tell me i could see around 100 additional horse power when done.
Old Nov 24, 2009 | 9:23 PM
rubrhammer's Avatar
If you put the 6.0 heads on you will drop your compression ratio (CR) as the chambers are 71cc vs 61.15 on the 5.3 heads. Not a good move unless you plan on adding a turbo or supercharger.
See here: http://www.smokemup.com/tech/ls1.php
Here is a link for 100hp gain
http://www.ls1truck.com/forums/front...in-budget.html
f22christian
Mar 29, 2015 9:52 AM
1956midwaywagon
Feb 8, 2011 1:05 PM
rmitch47
May 7, 2010 10:55 PM
